Flexible sprinkler drop
Does anyone know of any clarification of NFPA 13 2019 edition 17.4.1.3.3.3?
"17.4.1.3.3.3* Where flexible sprinkler hose fittings exceed 6 ft(1.8 m) in length and are supported by a suspended ceiling in
accordance with 17.4.1.3.3.2, a hanger(s) attached to the structure shall be required to ensure that the maximum unsupported length does not exceed 6 ft (1.8 m)."
Is this referring to only the flexible hose itself or would the armover be added. For example, a 6' flexible drop is connected to a 10" armover. Would the 10" armover need to be hung due to the assembly being longer than 6'?
RE: Flexible sprinkler drop
