NickParker
- Sep 1, 2017
- 446
Im an Electrical Engineer and new to Oil and gas. The below listed are some of the main loads of the FPSO which I got to know from the Key One line diagram. I would like to know some basics of the below loads like what does it do? when does it operate? sequence of operation? which of the load operate during normal production? which of the load must run during non production? etc?
Can any one help me out or point out to the correct document on the internet to refer to..
1. Sea Water Lift Pump
2. Produced Water Recycle Pump
3. Cooling Medium Pump
4. Water Injection Pump
5. Water Injection Booster Pump
6. HP Feed Pump
7. Produced Water Re-injection Pump
8. Injection Gas Compressor
9. Main Gas Compressor
10. CO2 Gas Compressor
11. VRU Compressor
12. LP Service Pump
13. Heating Medium Pump
14. Crude Oil Pump
15. Electro Static Treaters
16. TEG Reboiler Electrical Heaters
17. TEG Lean Circulation Pump
Thank you!
6. HP Feed Pump
11. VRU Compressor
12. LP Service Pump
14. Crude Oil Pump
Thank you!
