Contact US
Abaqus 2022 Eigenstrain Additive Manufacturing
Good morning,
I'm trying to use the AM plug-in in Abaqus 2022.
I've run into a few hiccups and am looking for help.
The example found at this link, with the given input file, generates errors that variables are not recognized or supported, even though the file is directly from Dassault.
Secondly, the AM plug-in requires Eigenstrains as an input. Using the inherent strain method of AM simulation, those Eigenstrains are computed from a thermomechanical simulation of just one or two layers. However, EEIG is not recognized as an output. I can use IE and THE as an output workaround, but I'm new to doing a sequential thermo-mechanical simulation. The example on the Dassault site has multiple input files, and has similar issues with errors of "keywords/parameters not yet supported by input file reader". On top of that, the thermo model has missing section assignments and property definitions. I also don't know how to feed the output of the thermo simulation into the mechanical input file. I'm very lost on this and the documentation is lacking, to say the least.
Does anyone have experience with Eigenstrain AM simulations? Any help appreciated.
RE: Abaqus 2022 Eigenstrain Additive Manufacturing
Search in abaqus documentation "Importing a model from an Abaqus input file". Not all keywords of input file are supported in CAE GUI.
Importing directly in CAE=> model gives warning regarding the keyword not supported yet. You can use Keywords Editor to include functions not supported. For details see "Adding unsupported keywords to your Abaqus/CAE model"
It’s better to avoid importing inp files to CAE in such cases, unless absolutely necessary. Depending on what you want to achieve, you can run the analysis from the command line (without the use of Abaqus/CAE) or import what’s supported by CAE and recreate the rest. For example, you can import just the mesh, create geometry from it if needed and do the rest of the setup in Abaqus/CAE with AM Modeler plug-in. It can be a good exercise to learn about AM process simulations in Abaqus.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
