Contact US
PTC Thermistors in LV Motors
How to consider PTC Thermistors in LV motors?
My understanding is that we need to consider a PTC thermistor where we get more heat in motors. Mostly we use them in VFD starter motors and large other starter motors. Who will determine the consideration of Thermistors? Electrical Design Engineer or Motor Manufacturer or others? Is there any general standard above what kW motors we need PTC thermistors? Please advise. Thanks.
RE: PTC Thermistors in LV Motors
Histor The ability to instrument equipment is a manufacturer responsibility. What that means is figuring how to do it in a safe, cost-effective, reliable fashion. The specific items that require instrumenting are usually defined by the equipment user, as it is often a function of how critical the machinery is to the process (or the financial bottom line). For equipment that is more critical to process success, or is more costly / time-consuming to fix, there is usually a higher degree of instrumentation. A "protect your investment" philosophy in action, if you will.
Instrumentation can be used to determine several parameters that can tell you about the health of the machine being monitored. These include: thermal sensors (winding and/or bearing temperatures, coolant temperatures, etc.), vibration sensors (bearings, drive train). power quality sensors (drive input/output harmonics, signal distortion, etc.), flow or pressure sensors (usually related to coolant but sometimes to lubricant), and so on.
The TYPE of instrument used to obtain a certain measurement is also usually defined by the equipment user - often because part of the control system is already existing, or there is an over-arching philosophy to it. For your specific example, there are multiple sensor types: resistance temperature detectors (RTDs), thermistors, thermocouples, infrared sensors, thermometers, bimetallic switches, and change-of-state (piezoelectric) devices. What you use is really up to you - and to device availability, in some cases.
In some cases, the user relies on the system designer to figure things out and create the specification. From the manufacturer's perspective, it makes no difference: it always boils down to "us" (the equipment - in this instance motor - manufacturer) or "them" (everyone else).
Converting energy to motion for more than half a century
Hi Hystor,
PTC thermistor ratings depend on the temperature rise of the motor. The OEM should perform several test in a prototype in order to determine what device should use and its ratings there are several methods for determining the temperature rise for the motors. IMO OEM is responsible for choosing the appropriate thermal protection for the windings in VFD-driven or standard motors.
Best Regards
Petronila
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
