Contact US
Can I do this with old footings/piers?
Have an old house with corbelled brick footings and piers. We are adding a camelback/addition which about 10ft of the camelback will sit on top of old existing structure with rest to be on new construction and foundation. Was told I could add additional single footings under existing structure to accept the weight of the new camelback.
I had some ideas.
1) Can I excavate around the existing corbelled single footings and jacket them with concrete? The new jacket dimensions would be 30"x30"x16" depth with proper amount of rebar. OR
2) Can I excavate and form a continuous 10ft footing and incorporate the existing brick footings?
The existing footings are 8" wide and reach a max length of 20" at about 16" depth. The new continuous footing would be 30" wide and 16" deep by 10-12FT.
Jeff
RE: Can I do this with old footings/piers?
I wouldn't want to jacket them in concrete. Shoring up the building, removing the existing piers, and installing a new foundation is going to be challenging and more expensive but will likely give you a better end product.
Way more expensive. Since this section is carrying about 12 feet or 10% of the new camelback I'm not looking to do the entire house. The front section has 10x10 sills that are still in good shape as well as the piers so do not want to disturb that.
If you live near the Amherst- Hatfield area of Massachusetts, I could check my archive for the name of a contractor that has experience with the type of work you described. It is always best to solicit ideas from people of similar mindset when you are in doubt.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
