Contact US
Calculate How Much Load A Flat Carbon Steel Bar Can Hold
Can someone remind me how to calculate a load a flat bar can hold?
The material is steel. The dimensions are 1/4" X 3" X 6".
RE: Calculate How Much Load A Flat Carbon Steel Bar Can Hold
Quite a bit if it is sitting on a flat thick steel plate.
P*L/4 = M = f*S --> P = 4*f*S/L
P is the concentrated load
L is is the distance between support points
f is the strength of the material (yield or ultimate, depending on how much deflection is allowed)
S is the section modulus = b*t^2/6
Well yes, but where's the teaching moment in that?
I always go back to the only useful structural equation (I exaggerate)
In the linear range M/I=s/y=E/R
With that little thing you can build models of tapered springs, beams with any load distribution, any number of supports, and composites.
In the rather banal case you have selected, at the centre of the span M=PL/4, I is 1/12bt^3, and y is t/2
Cheers
Greg Locock
Beam deflections should be covered in your strength of mechanics text books (or something similarly worded). If you're an internet fan and you just want the answer:
https://www.engineersedge.com/calculators.htm
You have to pick out the supports and loading case.
The question is not clear. A 1/4" x 3" x 6" flat bar can resist a tension of 3Fy/4 parallel to the 6" dimension and 3Fy/2 parallel to the 3" dimension.
BA
BridgeSmith,
You are assuming the bar is loaded as a cantilever.
JHG
Quote (drawoh)
BridgeSmith,
No, BridgeSmith is assuming the bar is loaded as a simple span with concentrated load at midspan.
BA
Hope this helps!
Quote (cole44)
This assumes that the OP is referring to a concentrated load at midspan of a simple span, which is not clear from his post.
If P is the applied concentrated load, then f is the allowable stress, about 0.6Fy.
If P is the factored concentrated load, then f = φFy where φ = 0.9, and S = plastic modulus = b*t^2/4.
In either case, deflection should be checked for acceptability.
Fultimate should never be used for this calculation.
BA
Thanks, cole44 for reposting what I wrote, but did you have a comment? Btw, it's common etiquette when you quote someone to clarify that it's a quote from someone else, and not your own.
Quote (BAretired)
Agreed. I did assume the bar was in bending about its 3" width dimension, simply supported at the ends of the 6" span. There are numerous loading conditions possible. Maybe I should have followed my first inclination and not bothered to respond to this thread. It's an ill-defined question that even a second year engineering student should have no problem with.
Quote (BAretired)
If ultimate tensile strength of the material is to be used, I suppose it would be correct to use the plastic section modulus to calculate capacity. As I alluded to in my previous post, the correct stress limit and section properties to use would depend on what constitutes failure - deflection beyond a certain value, yielding, or rupture/fracture.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
