Good morning fellow engineers,
I am working on a linear static analysis of a part(as shown in attached pdf) which is attached to concrete wall with 8 hilti anchor bolts. I am trying to find out the shear and tensile load acting on the anchor bolt due to load(as shown in pdf). When I use the foundation bolt, then the results I got on shear and axial load is shown on the attached pdf which is definitely incorrect. I am trying to understand what am I doing wrong.
I could use the other approach where I create a split surface to represent the washer and then set a fixed face constraint on that and eventually find the reaction load on that fixed face. But then I run into problems of stress singularities during mesh refinement. Also when the option of foundation bolt is there, there should be no need of alternate approach.
Thank You
KD
Thank You
KD
