Extension of a data network
I have a question regarding extending an existing data network to a new building. If there is only one data point required in the new building would a switch still be installed ? Is there another way to take the existing network to a connection point in the new building ?
RE: Extension of a data network
Surely you realize that your question is too general to answered meaningfully.
TTFN (ta ta for now)
Brad Waybright
The more you know, the more you know you don't know.
Higher data speeds are possible than for fiber, which you might or might not need.
Thanks again
If you are going to use fiber optical cable you need to check what kind of cable is the best for you (Multimode or Monomode)
Check if you have the right transceiver to match the cables or if you need to pruchase some media converters.
Check if there is enough space in the rack for the optical distribution box and switchs.
Check the cost for the splicing and testes.
