Hello friends, I am having trouble with the estimation of the bending moment acting on an aircraft rib. The method shown in the images attached was given by a teacher at the university. I know how to do all the calculations up until the bending moment diagram, there I am struggling, since that was I've drawn bending moment diagrams was to use the areas under the curve of the shear diagram, but for this case that doesn't seem to work, or maybe I am doing something wrong ( most likely).
I really don't understand where the bending values are coming from.
Look at the rib freebidy - The skin shears contribute to bending moments, not just the vertical shear.
Once you account for the skin shears your BM plots should make sense.
"...The method shown in the images attached was given by a teacher at the university. …"
Regards, Wil Taylor
o Trust - But Verify!
It is kinda like a student problem to shows how to initially dimension a light rib, taking the shear force to size the web of the rib and bending for the flange. Just i cannot find the correct bending, the shear diagram is easy, I took the component of the vertical shear in the a-d and b-c sections, but when i try to get the bending i just cannot find the correct one, between a-d and b-c, and thus my diagram doesn't end in 0.
I glassed over problems like this in school cause I knew I'd never be the one doing that... I just figure out how to make stuff. I have Bruhn sitting on my shelf with crisp pages still.
I enjoy seeing this stuff/been afraid to ask sometimes.
I fear mine will. Was never my world. But my 43.13 and machinery handbook have taped spines and coffee stains. If I'm missing my starrett scale its in the thread charts.
When we were introducing FEA at LandRover/Jaguar 4 decades ago lucky greg was the one who got to build FEA models of the worked examples in Bruhn and than try and puzzle out what was wrong, ably assisted by my manager, who knew Bruhn backwards.
Try accounting for the horizontal component of shear flow in the skins, not just the vertical component. I haven't run the numbers on this one, but that is usually where people slip up with these problems.
While I get that the reaction system with 4.09N/mm shear flow reacts the torsion, I do not understand what it does to the rib. For example, what if there was no rib in this system (when looking at torsion alone)?
Dik: this topic pertains to bending in the plane of the rib web, (not wing bending).
Jp: for a wing in pure torsion, if there were no rib at this station, the macroscopic effect would be greater warping of the wing cross section (wing becomes more torsionally flexible), at a detail part level the onset of panel buckling would occur at a lower load.
Thank you for helping keep Eng-Tips Forums free from inappropriate posts. The Eng-Tips staff will check this out and take appropriate action.
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Metal 3D printing has rapidly emerged as a key technology in modern design and manufacturing, so it’s critical educational institutions include it in their curricula to avoid leaving students at a disadvantage as they enter the workforce. Download Now
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
RE: Bending moment acting on an aircraft rib
This problem looks suspiciously looks a student problem ?
Regards, Wil Taylor
please note, student posting is not permitted.
Cheers
Greg Locock
One takes about an hour to set up and seconds to run. The other takes about a month, but brings far greater satisfaction.
The F/S reaction is approx 1878N and the R/S is ~250N. The remaining ~255N comes out as the vertical component of the shear flow in the inclines.
At the front spar, it's just 3.56*260*260/2=120,328N/mm. (Matches)
At 332.5mm, the bending moment is 3.56*332.5*332.5/2-1878*(332.5-260)-4.06*sin(6.2)*(332.5-260)*(332.5-260)=58,310N/mm. (value quoted is 82,468N/mm)
Rather than think climate change and the corona virus as science, think of it as the wrath of God. Do you feel any better?
