V 9.3.1 Required Minimum Level of Liquid to be maintained Inside Tank
Equation in edition 13 for estimating the (Required Minimum Level of Liquid to be maintained Inside Tank) written as;
(Gin x Hin) + Wbott  / (p x R2)3 Gout × Hout =
noting that Hin in above equation is defined as (Height or Depth of Liquid Inside Tank).
Coming To;
Same Equation in edition 11 written as;
(Gin x Hin) + Wbott  / (π x R2)≥ Gout × Hout
Which look more logical? which one is correct?
In case the equation in edition 13 is correct; shall I divide Wbott by the total value of [(p x R2)3 Gout × Hout] or it shall be divided just by (p x R2)3 & multiplied by the rest (Gout × Hout)?
Also, R defined as Roof Dish radius; which isn't make sense, it should be bottom plate radius?
Mohd Yaseen
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
News
Close Box
Join Eng-Tips® Today!
Join Us             Close
