MICROSTATION TO CAD CONVERSION (.DGN TO .DWG) 1
Alfred Philips
QA
Hi all,
Is it possible to convert Microstation (.DGN) file to AutoCAD (.DWG) without any data loss.
My subcontractor has given .DGN files and i need to convert them urgently.
Any help will be appreciated.
Try AutoCAD command DGNIMPORT.
See AutoCAD help for limitations on the command.
Microstation has a drawing converter. Can you have the contractor save the files as *.dwg files?
