Hi i am looking for the smallest
Hi
i am looking for the smallest possible solenoid , to fit in a 6 mm (diameter) x 14 mm space. Googled this but no luck so far. rotary or push pull type, custom maybe but prefer a stock item. its to swing a 8 gram shutter 0 to 90 degrees. with push pull i would need a mechanism to convert linear to rotary motion. i believe such small solenoids are used in smartphones and some printers. would greatly appreciate any help as its not my area of expertise
many thanks in advance
Sunclipa
Sunclipa
RE: Hi i am looking for the smallest
TTFN (ta ta for now)
thanks
best regards
Tony
YOU need to calculate the amount of power/torque required to move your shutter in the time YOU require to determine whether what you are seeking is even plausible. Just because you can imagine, or create a space claim for, something does not make it realizable. We call that unobtainium.
this is not really my field. My plan was to engage someone to help if and when i found the key device. if it cant fit into the space its would not be a viable product. Fast speed is not needed. 0.5 seconds to switch between the two states would be fine.
thanks
best regards
Tony
thanks
Tony
best regards
Tony
