Hi all,
I'm new to Abaqus and trying to model a 1.4 kg weight laid on the buttocks.
I have a complete buttocks model with element type C3D4H for the hyper elastic materials and C34D for bones.
I assigned boundary conditions of encastre to the bottom part of the buttocks, and the weight can only move in the Y direction toward the buttocks.
I'm using prescribed displacement of the weight and measuring the RF2 on the top nodes of the weight and trying to get ~13.7N (1.4*9.81).
I've assigned surface to surface contact with 0.8 COF between the weight and the area of the buttocks in contact.
I cant seem to get convergence at other part rather then the middle of the buttocks, when the weight is above the peak height...
I tried many things but cant get it to converge, It start to get really slow around 80% and diverge at around 95%.
Also the deformation seems a bit large for this small weight.
I would really appreciate some help, I'm attaching the cae file with 3 locations of the weight I tried.
Thank you,
Tomer
Thank you,
Tomer
