OMRON CP1EN40DT1-D PLC - PULS2 INSTRUCTION
srini1785
IN
I am trying to control a Step Servo Motor (EX d) using an Omron CP1EN40DT1-D CPU. The task involves positioning control of a belt pulley system for positioning the carriage using a Step Servo motor. So its a position control application. I am trying to use the PULS2 instruction to limit the number of pulses so that I get the precise movement in mm of the slider/ carriage. Problem is I am getting nowhere. The program is attached.
Am i correct in choosing PULS2(887) instruction for such a task?. The problem is that the output(Port 0, 0.00) does not even go ON. The program is attached. I am able to use PULS(886) and SPED(885) function block to output the pulses but am not able to use PULS2 for limiting the number of pulses. Any help is appreciated. Thanks.
 https://files.engineering.com/getfile.aspx?folder=031ea6db-25b6-4156-9918-5a500181f64e&file=Pulsing_Testing.cxp
