If you look at research that has been done using electrochemical methods, it is apparent that the natural potential (in fresh flowing seawater) would be similar to other alloys with similar pitting resistance.
These would be 6% Mo superaustinics (not the leaner alloys such as 254sMo) or even the superferritics.
One thing that we have learned over the years is that when working with this class of materials coupling them with more noble alloys (NiCrMo or NiMoCr) there is not enough potential difference to cause issues in seawater. Some special chemical process environments may be another issue.
Just as a general caution, the super duplex alloys require the strictest process control and oversight of any alloys in use.
Rigorous attention, especially to the heat treatment, welding, and corrosion testing are required in order to assure suitable performance.
If a supplier does not have a long history of doing this work and is not very open about it, it is time to move on to a different supplier.
