StrucPatholgst
Have a client with an 1880's balloon frame stick home. Rear half of the second floor framing was butchered by a plumber early in its history. Ceiling below was opened to investigate a crack in the plaster, and revealed a nightmare. Joists are true 2x7.5, and 2/3rds of the joists are unsalvageable. There are 6 inch wide U-shaped notches present that cut 2/3rds deep into each joist. Second floor is 15 feet wide, with 2.25 inches of settlement at center span. Center span has a framed wall that carries the center of the attic floor. This wall is currently hanging from the attic floor (I can stick my hand under the wall from one room into the other).
I have no cost-effective option for sistering, since an earlier (1950's?) attempt was epoxied to the notches. I plan on replacing each "legacy" joist with a double 2x10 ripped to 8 inches. I'm losing about 1/2 an inch of headroom in the room below (this is acceptable to the client). As for attachment at the perimeter, I will be blocking the perimeter wall studs behind the ribbon, and supporting the new lumber off of the blocked ribbon.
At the very end, a plumber will rerun the toilet drain in 3 inch PVC through the joist bay to the perimeter wall down to the basement. Shower and sink will follow their existing path.
Question, is there an easier way to do this? I feel the existing floor is so butchered that it can't be saved. I see cracks and splits everywhere.
