TugboatEng
Marine/Ocean
The operator wants to keep the report confidential citing security concerns. That's usually a bad sign.
Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
spsalso said:...We have here a likely testimonial to my new product: Spray-on CYA. Simply apply where needed...
pdf said:The inability to detect and mitigate the presence of excess water under pressure and at high temperature within the facility’s reheater system.
accumulation of water in an offline heat recovery steam generator (HRSG) due to the mechanical failure of a gearbox on a cold reheat stop valve…prevented the valve from fully closing … causing steam to pass through the valve and condense in the offline HRSG
the colder water from the offline HRSG passed through the hot valves feeding the steam turbine, the valve components were thermally distorted … preventing their closure.
The continued flow of water followed by the flow of steam through the seized valves provided the energy source to accelerate the steam turbine into the overspeed event.
