ASTM B-190 TYPE II
ASTM B-190 TYPE II
Hello everyone,
Looking to see if anyone has material properties and chemical composition of this material spec? Having a hard time finding it anywhere. I found that it was superseded by ASTM A447 at some point. I have the specification for that material, but the material properties changed a bit so looking for the original. It is a Chromium-Nickel-Iron Alloy Casting (25-12) and I know the tensile strength is 50ksi for type II. Looking for additional info. It is currently being used as a tube support (bull horn) in one of our furnaces.
Thanks in advance!
Thanks in advance!
RE: ASTM B-190 TYPE II
Of you could call here and buy a copy of what you need through them
Linda Hall Library
Tel: 816-363-4600
