Contact US
Bearing Pad Check
Bearing Pad Check
Bearing Pad Check
Contractor made an error in placing the girder. Girder web is not concentric with bearing pad after girder erection. Center of girder web is at an offset of approx 1.5" from the center of bearing. What calcs does one show to justify this shouldn't be a problem ?
RE: Bearing Pad Check
Is the bearing pad offset or the girder? Isn't there an end diaphragm there? wouldn't that inhibit the placement of a diaphragm or the cross frames near girder end?
I would have them jack and reset it or THEY should demonstrate it's ok to leave as is. You shouldn't have to justify a contractor error unless the owner is asking you to verify.
Sounds like a project I have under construction. The girder is in the right place but the bearing is off. The bearing manufacturer submitted calculations showing the bearing will work; although the owner may have a different opinion.
@Bridgebuster, what kind of calculation was it ? Do you have any info ?
@Mike 311, the bearing is at an offset.
The only effect I can see is a small torsional moment on the girder due to the eccentricity between the bearing load and the center of the supporting force. Assuming the flange is adequately supported by the bearing stiffeners, and the cross frames/diaphragms can resist that moment, I don't see an issue, unless the shift in the bearing load applied to the seat causes an overstress in the cap.
@ATHS - on my project we have multi-rotational disc bearings with sole and masonry plates. The manufacturer checked all of the components. The only thing that was affected by the eccentricity was the thickness of the sole plate. However, the thickness provided still exceeds what is required.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
