Measuring quantum of smoke
Nodbek
IN
Hello All, Can i get a recommendation on a way to measure density of smoke from a system? I see smoke detector circuits but unsure if they can help me measure density.
Nodbek
To what end? You can look at the sensitivity of the detector and determine the minimum detectable density. Smoke has no intrinsic density, which is why you can sometimes see through it and sometimes not.
TTFN (ta ta for now)
I'm testing various vape machines and looking for a way to measure the smoke output or atleast come up with a way to spec it. Any suggestion are truly appreciated. Thanks a ton.
Thanks a ton. Will check it out. Have a nice weekend.
