HVDC Warning Indicator
I am looking for a way to indicate danger in a HVDC (80-1,000 VDC) junction module when dangerous voltage is present even when the machine is shut down. The system I am working with can have stored voltage of up to 1,000 VDC. I am thinking that I could use an LED that is connected to the HVDC through a current limiting resistor that would stay on down to about 40-80 V and then go off.
My constraints in order of importance are 1. space efficient, 2. simple, 3. cost effective.
So far for this I have used a DC/DC Converter to drop the 80-1,000 VDC down to a regulated 12 VDC to power a TruMeter Voltmeter. It has been working well, however, this method meets none of my constraints.
Thank you in advance for any suggestions!
RE: HVDC Warning Indicator
You could begin experimenting with a typical 115VAC neon pilot lamp. These usually contain internally a 220K to 270K resistor in series. Just add more resistors in series. A single typical axial 1/2 resistor should not be used at more than 500V which is why I suggest several in series.
