GRLWEAP - How to calculate "Pressure"
JHeisenberg
Geotechnical
Nov 30, 2015
17
I know Energy = Stroke Height X Ram Weight.
I am curious how pressure is calculated in the Hammer Parameters. For example, in the GRLWEAP hammer table a pressure (psi) is provided for each reduced fuel setting. How is this calculated?
If I am provided a fuel setting of energy XX (k-ft) from a contractor, how do I compare this to GRWEAP fuel setting of pressure XX (psi).
Thanks!
