FEA Software Options
If you were tasked with selecting FEA software for your company, which one would you choose? And why?
Thank you!
Thank you!
FOR ENGINEERING PROFESSIONALS Contact USThanks. We have received your request and will respond promptly. Come Join Us!Are you an
*Eng-Tips's functionality depends on members receiving e-mail. By joining you are opting in to receive e-mail. Posting Guidelines |
RE: FEA Software Options
There's an article titled "5 Tips for buying FEA Software" on Simuleon's blog - you may find something interesting there.
Cheers
Greg Locock
civil eng or other ? civil seem to have their own preferred codes (RISA, no recommendation), other will use lots of codes (ANSYS, SolidWorks, FeMap, PATRAN/NASTRAN).
simple FEA or something more colourful (dynamics, hyper-elastic, ...)
There is, IMHO, no "best" code. All should give the same answers (with the same mesh), some are easier to learn than others. The biggest difference is the pre- and post- processing.
Most comprehensive and popular packages- Abaqus and Ansys for most mechanical products right from Pre-processing, solving and post-processing.
Based on your requirement (Your product, what you want to do CFD/FEA or combined together, just design based introductory analysis, full fledged complex analysis like crash of car, fracture mechanics, non-linear material simulation like hyper-elastic/plastic, plastics, visco-elastic/plastic etc.), there are different packages which can be used.
This link may help in shortlisting and decision making.
This topic has been hashed and rehashed quite a number of times on this forum. Follow the discussion in these links for some perspective:
https://www.eng-tips.com/viewthread.cfm?qid=378607
https://www.eng-tips.com/viewthread.cfm?qid=120567
https://www.eng-tips.com/viewthread.cfm?qid=67468
https://www.eng-tips.com/viewthread.cfm?qid=74650
https://www.eng-tips.com/viewthread.cfm?qid=4390
https://www.eng-tips.com/viewthread.cfm?qid=37632
What software I would choose is easy. I would choose the software I have used for many years. But I think you need to ask yourself a few questions to start with.
- What is your budget?
- What are your analysis requirements? It ranges from linear static and up to non-linear dynamics including multi-physics. And there are also "side-tracks".
- How will you interact with the software, or requirements for pre/post software? Manually build a model or import a solid and auto-mesh?
My impression is that you think there is a single software that is the best for all types of applications. My experience is that there is no such software.
Good Luck
Thomas
