Pressure Drop Comparison for Globe / Butterfly / Gate & Ball valve
My question is about the Pressure Drop Comparison curve,which is shown The Min Drop is for Globe type .
However ,at Normally condition Globe type should has a high pressure drop and gate should be less .(Is it only at the Fully opening Condition or at the all condition)?
RE: Pressure Drop Comparison for Globe / Butterfly / Gate & Ball valve
The chart is not showing the pressure drops when the valves are fully open.
Thank you for your reply.
Please confirm in the case of full opening condition, the pressure drops of globe valve is more than all types .
So the others when fully open as a full bore valve is basically the same as a pipe.
A globe valve has lots of bends and restrictions.
That graph has nothing to do with it.
A gate valve is not shown.
Good Luck,
Latexman
to elaborate a little, the lowest pressure at the vena contractor has a implication if it goes below the vapour pressure, then you will get cavitation in your valve and it will wear out quickly. Its interesting that a ball valve has such a high pressure recovery but you chart is somewhat misleading or can cheat you since it must represent a situation where FLOW is not similar for the various valve type because then, of course, ball valve would have the lowest total dP of the four types.
So you will rarely see cavitation in a fully open ball valve - but i guess the chart also add to the explanations as to why you dont use a ball valve for flow control if you can avoid it.
Best regards, Morten
--- Best regards, Morten Andersen
In this regard,I am not sure about possibility of replacement of Segmented Ball Valve with Glove type in order to prevention of Cavitation or choking
bcd called it correct in the first post, but you don't seem to have understood?
That chart you put up is a bit of nonsense. What it is trying to show is what happens when you use any of those types of valves as pressure reduction / regulating , i.e. with a constant dP. Now assuming that the graph is proportional, the fixed DP is some 40% of the inlet pressure. Hence for a ball valve it will be probably about 95% closed.
All that it shows is that, surprise surprise, the valve which is actually DESIGNED to regulate pressure - the globe valve - is actually quite good at it and the others are not so good.
If you only want to isolate, use a ball, gate, butterfly or plug valve. If you want to control pressure or flow, use a globe valve. If your pressure drop is low as a percent of inlet pressure, a butterfly valve can be OK as well.
What do you want this valve to do??
