metrologic
Sr GDTP Y14.5-2009 Exam Review Ch-6 Sep2021
Hi Everyone! I'm up to section 6, Tolerances of Orientation. As you may recall, I'm working through the Y14.5 standard in preparation for upgrading my GDTP certification from the tech level to the senior level. Here are some questions I had on this section:
Q1. 6.4.3 Tolerance Zones. "Although orientation tolerances are only constrained in rotational degrees of freedom relative to the referenced datums, the notation of EACH RADIAL ELEMENT adds a requirement for the tolerance zone(s) to be constrained in location relative to the axis from which the radial elements emanate." The rules for checking controls with EACH ELEMENT always seem rather ad-hoc or poorly defined. They seem to break the overall pattern of Y14.5.
Q2. Fig. 6-16 Specifying Perpendicularity for a Radial Element of a Surface. Does the perpendicularity control in this figure apply to what appears to be the bevel at the base of the datum A cylinder? Or does the control refer to only the surface seen on edge that is directly in contact with the leader arrow head?
