SA07
- Feb 22, 2018
- 373
Hi
We are a power plant exporting to the utility network. We have a fault recorder, SEL387,SEL 311 connected to a time synchronizer SEL2407 and using a GPS antenna. However in our control room we must manually synchronise the time on a master PC with the time at the utility control room. They do not have GPS time. We need to do so to avoid getting penalty to adjust MW exported as requested by utility control room within the delay requested.
There is a request from Operation Dept to synchronise time on the fault recorder, SEL 387, SEL311 with the master PC in our control room. Is it possible to configure the SEL2407 to take the time from the master PC instead of the GPS antenna?
