Convergence error in calculating SIF using XFEM approach
Naman Verma
Student
IN
I am trying to calculate SIF using XFEM and getting this error
THE PROCEDURE TO GENERATE THE SAME SEGMENTS ALONG THE CRACK FRONT FAILS TO CONVERGE IN SMAPrepre_contour_sameseg
Hoe to solve this error
Which version of Abaqus do you use ?
There’s a great chance that this error will disappear if you update Abaqus. Either install the newest fix pack or (even better) a newer release of Abaqus.
