Paraffin Wax Actuator Design guide???
Hi All,
Does anyone know of a good reference book on designing these type of thermal actuators?
I know S. Vernet from his early patents showed examples back in the 1930's - 1950's but was wondering if anyone ever came across a design guide.
TIA
~Q
TIA
~Q
RE: Paraffin Wax Actuator Design guide???
Cheers
Greg Locock
FWIW...an electric motor actuator will usually be more efficient than a wax actuator if you are operating at near room temperature (i.e. you apply electrical heating to make the motion you want). Reason being that the motor can move to a position and hold it (with suitable non-slip gearing), but the wax pellet requires constant thermal input to hold a position other than its "cold" position. Places where wax motors work well is in thermal regulation, where operating temperatures are within melting range of wax/oil mixtures.
