UD preperg + SMC CF compression moulding problems
Hello Gents,
we were working compression moulding of UD preperg + SMC carbon fibre and we do face many challenge which are the following.
1)unable to achieve the required part height most the case we are +2 more than required heights
2)Resin pooling / resin richness in few area.
any suggestion for the above concerns.
Many thanks in Advance
RE: UD preperg + SMC CF compression moulding problems
- part geometry
- tooling geometry
- bagging and pressure intensifier details
Cross section sketches thru the problem areas would help also.
+2 what? mm? plies? inch?
