Air Cooled Heat Exchangers Inspection
I'm working at a small plant and we are trying to development an inspection procedure for our fin fan coolers.
We know how to internally inspection the tubes using ECT but we are having a hard time searching for information regarding inspecting the blades, header boxes, fin fans, etc. Most of the information i find online is about internal inspection of tubes but there is little information regarding those other parts i listed in the previous sentence.
Basically i am having a hard time figuring out what exactly to look for in order to know if repair, replacement, modifications, etc are needed.
Thank you
Thank you
RE: Air Cooled Heat Exchangers Inspection
Your supplier should have a maintenance doc of some kind. What brand units do you have?
