Why have big different between KissSoft & MITcalc???
Ryan.z
4
Helo everyone
have a good day
I design a spline coupling and I conpare between 2 calculation software: KissSoft & MITcalc
I found an abnormal result. This is permissible pressure value of material.
I select same material, same hardness, there's a different as image below. anybody can explain why permissible pressure different so much? please. and how to calculate permissible pressure from tensile strength?
Ryan
Try entering custom material with the same tensile and heat treat properties.
then contact each of the software engineers, they will help you with this.
