Trench Shield
Trench Shield
Looking for references applicable to the design of trench shields. H = 10 ft. or less. Have not been able to locate much. Thanks
FOR ENGINEERING PROFESSIONALS Contact USThanks. We have received your request and will respond promptly. Come Join Us!Are you an
*Eng-Tips's functionality depends on members receiving e-mail. By joining you are opting in to receive e-mail. Posting Guidelines |
RE: Trench Shield
I'd do a google search for trench shields, unless you've got a hankering for doing it the hard way.
RE: Trench Shield
RE: Trench Shield
RE: Trench Shield
RE: Trench Shield
If you are building the shield from scratch, the entire shield needs to be designed. Is the depth 10 feet or 4 feet? You mentioned both depths.
www.PeirceEngineering.com
RE: Trench Shield
RE: Trench Shield
RE: Trench Shield
I would be careful about just using an apparent earth pressure chart - if you have a trench failure which is probably the only time it will actually be supporting anything the load may be higher than predicted by Peck's charts.
RE: Trench Shield
RE: Trench Shield
RE: Trench Shield
The shield is needed due to unstable soil and a nearby pavement. Water table is about 30 inches down. Soil is stable above that. They plan to excavate 30 inches, place the shield, then excavate the remaining 10 inches from inside the shield, pushing the shield down as they go.
RE: Trench Shield
RE: Trench Shield
RE: Trench Shield
