PRV with Dual Certification - ASME & CE
Hello all,
I need your help with finding a pressure relief valve for steam application that has dual certificate - ASME ("UV" Stamped) and CE (PED 2014/68/EU).
Some general information regarding the PRV I am looking for:
Approvals: ASME/NB certified "UV" stamped, CRN, "CE" marked.
Inlet Size: 1/4" NPT.
Set Pressure: 40psi/2.8 Bar.
I've been trying to find PRVs from "HEROSE", "Kingston" and "Apollo" but none of them match me needs.
Any help will be much apricated
RE: PRV with Dual Certification - ASME & CE
Good Luck,
Latexman
Your main problem is the inlet size of 1/4"
Note that if liquid application, the smallest permissible inlet size following ASME XIII is 1/2".
Brands to try are Kunkle (Emerson), Bailey (Emerson), Seetru (UK)
*** Per ISO-4126, the generic term 'Safety Valve' is used regardless of application or design ***
*** 'Pressure-relief Valve' is the equivalent ASME/API term ***
It is steam application, indeed, the 1/4" is an issue here.
Kunkle and Bailey don't do 1/4" PRV.
Seetru has 1/4" but only CE marked.
I need both ASME and PED because holding one type of inventory is cheaper and my company sells worldwide.
I seem to recall PED not including equipment such as 'simple pressure vessels' of a certain volume.
You best tackle this with your engineering/QA people to determine whether ASME and PED apply.
Failing that, your best solution would be get a manufacturer with existing ASME and get them to obtain PED certification for the selected size/type of PRV based on the potential of future business of sales of your autoclaves. Either that or consider a larger size PRV and/or bursting disc.
Exactly what I did, waiting for an answer.
Thanks.
