Silicon/Rubber molding for a Bracelet product
Hi all
I am looking to design a bracelet product where the middle part is made of a more flexible material like Rubber/Silicon.
My question is can a part as shown in the attached image be molded as one part ?
The part is more like a hollow tube in the shape of the letter "C"
Any comments would be welcomed.
Raminee
Raminee
RE: Silicon/Rubber molding for a Bracelet product
I doubt the part can be moulded as one because I cannot see how you can remove the central core after it as been moulded, if the c shape wasn’t hollow then that would be a different story.
Just from the drawing, it can be molded as one part.
What's the thickness of it?
David
Mechanical project manager
JLFY technology company
Https://www.customized-tech.com
I am intrigued to know more as to what your thinking is. Can you share more ?
Attached is the intended dimensions.
What will be the material of the part you displayed? I'm not asking the mold material.
The different material will decide which way will be used.
David
As the title suggests it would be something flexible like Silicon or Rubber.
I would prefer Silicon but then again I am not a material/molding engineer.
However I want the part (once it is out of the mold) to hold its shape. So maybe a higher shore rating.
But not stiff. Something around 0.8 so that it would be flexible enough to open the jaws when it is being placed on the wrist.
Silicon material is ok.
The silicon durometer I touched is always from 20A to 80A.
For doing it, the way is to use flow mold instead of injection mold.
(If the material of the similar design is metal, the best way will be bent machining if the R is enough)
Hope that can help you get some points.
David
