Overhead Crane wheel standards/allowances
Can anyone direct me to a website or give me information regarding crane wheel standards and acceptable wear. Especially for the flanges.
Thank you
Thank you
RE: Overhead Crane wheel standards/allowances
Not sure if page 24 is what you're looking for, hope that can help you.
David
Mechanical project manager
JLFY technology company
Https://www.customized-tech.com
that ISO document saved as I managed to get it through university. Helpful but it doesnt seem to have anything relating to flange wear. Cheers guys
What problem are you trying to solve?
On this particular crane a drive wheel outer flange recently collapsed after what looks like excessive wearing and allowed the wheel to roll over the rail onto the opposite side. I have just been up and checked the wheel diagnoally opposite it also has wear on its outer flange well past the 50% allowance
It suggests to me skewing. I also believe im hearing lots of creaking and popping noises which I havent noticed before.
I want to be in a position to diagnose problems properly and suggest the proper solutions.
Ive been told the rails were recently realigned so that shouldnt be the issue. Id like to check the drive assembly for backlash that would cause skew as I believe the issue could be routed in here. I believe the wheel diameters should be checked but im unsure how to do this accurately.
This document Diagnosing Bridge Crane Tracking Problems Prepared By Gary J. Davis, P.E. copy attached, provides some general guidance.
Not addressed in the linked document
If you have a wheel with 50% flange wear, you also likely have tread wear.
If the wheel tread is spalling, pealing, or out of round the case hardening has failed. The wheel should be replaced.
Drive wheel circumference must be nearly equal. This is more critical when drive wheels are mechanically linked. A PI tape is a good method for measuring tread diameter.
