SW2020 Envelope Publisher
freerangequark
88
I'm a new Solidworks user, but well versed with Creo.
Within SW2020 I am working on a new assembly on which I am wanting to try out the SW2020 Envelope Publisher for top-down design.
I have my basic envelope created. I have also published it to a subassembly so that I can reference the parts in that subassembly to the published envelope.
When I make a change to the envelope model, the change does not appear in the subassembly's published envelope.
I have tried using the rebuild command and the published envelope isn't following the top-level envelope.
What might I be doing wrong?
How best can I emulate Creo skeleton, top-down, publish geom, copy geom features in SW?
Glenn
freerangequark,
I have not used the envelope feature of SolidWorks.
You can create a part file, and place sketches in it, and attach the file to your primary assembly, and all the sub-assemblies in your system. The sketches can be 2D or 3D.
JHG
