That's my fellow manufacturing engi
John Donlan
Aerospace
Nov 28, 2021
6
That's my fellow manufacturing engineers know, when you haven't solved a problem... Even after many years... It's still begs for a solution in your mind. I would gladly appreciate your help and advice with this problem.
It's been many years (1983 - 1984) since I've written programs to turn hastelloy B and hastelloy C parts on the CNC lathes. Of all the aerospace and super alloy materials that we manufactured... These two were the most difficult.
Hastelloy C, and to a greater degree hatelloy B, had to be turned had a very slow speed (90 SFPM), and at a very generous depth of cut (.050 - .100"), and flooded with a constant stream of coolant.... And even then the carbide inserts would wear out prematurely. Hastelloy work hardens very easily... And it generally runs very hot. The chips come off almost flaming.
We tried experimenting with "Cerratip" ceramic inserts, but they would disintegrate almost immediately due to the extreme cutting pressure.
Would anyone like to share their current methods for machining these two materials, including workable speeds, feeds, depths of cut, and brand and grade of cutting tool inserts?
Not my area of expertise.
But I did a very quick broad search for "hastelloy" on practical machinist dot com. Lots of discussions on the problem of machining hastelloy and other nickel alloys. You could probably find more discussions on CNC Zone dot com, too.
TygerDawg
Blue Technik LLC
Manufacturing Engineering Consulting
Thank you very much for your suggestion! I'll check it out.
