Servo Drive Repair
Servo Drive Repair
I have a Bystar 4KW 3015 laser and had servo drive fail 200 AMP 750RPM .I have replaced it twice over time with a used drive. I am reluctant to install the brand new one in case it fails due to problem down stream. Is there away of testing to see what caused the failure. Has anyone got any information on how to repair them.? Circuit diagram, bench testing.
RE: Servo Drive Repair
Where are you located?
Chris Krug http://krugtech.com/
Maximum Up-time, Minimum BS
TTFN (ta ta for now)
