Opinion of geomembranes?
Alex07
Industrial
What do you think of using geomembrane liners in portable water tanks?​
Do you mean portable or potable? Portable does not seem a very relevent distinction. With potable water the membrane must be certified for this use. Plastics can contain many additive that are not safe for ingestion, which can leach into water.
There are many types of lining which are less expensive. That is probably the reason that geomembrane liners are not used for this application.
