Acceleration consumption vs cruising consumption of bus/truck
I need to calculate the increase of consumption of a municipal bus if average distance between stops is halved e.g 125m instead of 250m. There is no regenerative braking on the buses. I'm assuming average traffic speed is the same. Acceleration and deceleration will be the same. Routes will be the same. I think instant consumption graphs (unit fuel per sec.) of NEDC or similar lab cycles would help but I couldn't find any. A comparison of acceleration period and cruising period consumption of buses or dump trucks or similar diesel/CNG vehicles would help. Citing a resource would help. I'm trying to argue against shortening the distances on basis of fuel consumption increase, so I need citeable data to base my rough estimate on. Jumping on a bus and following the on board computer (which doesn't exist or I don't trust anyway) for a few minutes is not an option. Thanks in advance. Sorry if I'm on the wrong page.
background: I'm a civil engineer.
RE: Acceleration consumption vs cruising consumption of bus/truck
Assumption 1: Acceleration profile is the same in both cases and maximum speed reached is the same.
Assumption 2: Fuel used during cruise at steady speed is negligible. Ditto for the fuel used during idle while stopped.
With these two assumptions, the number of accelerations is doubled, so the fuel consumption is doubled.
Cheers
Greg Locock
Three cycles with different start stop cycles.
The more frequent is about 15% more fuel consumption.
https://www.google.com/url?sa=t&source=web&...
I am pretty sure that won't be the case. Standstill to V to standstill over 125m in a bus suggests a very small value for V.
Don't worry about BSFC initially. It won't be much different so energy usage will be a good indicator.
I reckon consumption (and time to complete the route - ie wages) will both increase by about 50%
je suis charlie
... and, passengers are going to notice the increase in time to get to their destination. Customer satisfaction will go down.
Normal walking speed is about 1.5 metres per second. With 250 m between stops, you're not more than 125 m to the closest one. Cutting that in half saves about 40 seconds of walking time in the worst case. Won't take too many extra stops slowing the bus down to make the total travel time longer ...
Even if fuel goes up 50% my hunch is that break life will be cut by 50%.
I have always been surprised that there are not hybrid trash trucks out there.
With hundreds of short accelerations a day it would seem to be a good fit.
Do you have other bus routes with longer or shorter distances between stops and are fuel and repair records kept in such a way as to be usable?
Ohm's law
Not just a good idea;
It's the LAW!
