About Mascoat against CUI
Recently MasCOAT salemen come to our office to give a lecture on their product, and suggected that Mascoat is a best option to handle CUI(Corrosion Under Insulation). Anyone here has any experience on Mascoat? will you please give your opinions on this?
Thanks in advance.
Thanks in advance.
RE: About Mascoat against CUI
Leaving metallic surfaces bare under non adhesive insulation is looking for corrosion troubles (but some people like it because this is obsolescence and this is their business model).
* Finding a solution is great * Knowing how to implement it is fantastic * Believing it is the only one and best is naive ?
Steve Jones
Corrosion Management Consultant
www.linkedin.com/in/drstevejones
All answers are personal opinions only and are in no way connected with any employer.
Have the vendor to provide the actual product application and references.
Thankfully You defined CUI in relationship to this issue...
Word to all: be wise and always define abbreviations, when used.
For instance… CUI can also mean [DoD] Controlled Unclassified Information
Regards, Wil Taylor
o Trust - But Verify!
