Sealing a workshop concrete floor.
No heating temp goes down to -30.
Cars and tractors will be on it.
What would you seal the concrete with?
RE: Sealing a workshop concrete floor.
I might be able to find out what we uses at work if you want, but it is indoors, but there's a lot of ware on the floors there.
There is also product called Lithurin, seems to be some hokuspokus.
Albert Einstein
I am going back there next week after this work cycle.
I put plastic on it after 24h and can't make up my mine to leave it with plastic on until march or take it off. I had a look for sealant locally and the only time they seem to deal it is when they are going to tile it.
When I go next week I will check for cracking and cement any up before water gets in them and starts freeze thawing.
I am sure the kilt will do the job if you add some wool under ware.
Albert Einstein
I hear they use live sheep... road sign in Scotland, "NO EWE TURNS."
https://www.ppgpmc.com/products/AMERLOCK-SEALER
So the production people can do it.
This Lithurin not sure what it is, there is no good explanation of it more then it is a chemical reaction with the concrete that seals it and it sinks in.
Not particularly expensive either, not sure if that is good or bad.
Albert Einstein
It's one of these daft things reds. It seems to be a secret what to use that works.
The epoxy will more than like be 2 times the cost of the normal stuff. But that will need redone after 3 years. The epoxy stuff will be good for 12 plus.
How much per sqr ft or sqr m would you recommend?
Yes I always get a bit suspicious when there isn't any clear facts on how things work or a table of contents.
Either it's a new invention patented and they don't want anyone to find out or it is bogus.
Must admit I haven't looked around hard enough, things cant be sold here unless it has a table of contents and a hazard sheet.
If it is new it might be good though hard to know if there isn't any references.
Albert Einstein
Might seal it then put a warehouse floor paint over the top of it from the same company.
Usually the good stuff is now band for environmental reason's.
Don't want to have to empty the place every 3 years.
Another penetrating sealer uses methacrylate penetrants. These are very good, but they are expensive and add no surface enhancements to the concrete such as hardening.
The inside will be down to -30 in winter.
And i believe sealing will help with frost stopping water getting into the surface and then freeze thawing.
It all under 3ft of snow now.
Albert Einstein
Good to see you posting today. Take it you weren't working into Riga yesterday.
A
Good thing no one seems to have gotten hurt.
Albert Einstein
i was on the way back from my farm after fixing snow blowers . It was chucking down with snow.
Snow blowers??
Do you need more snow then you already have?
Albert Einstein
And of course during summer i forgot about it.
There has been 30 cm fallen in the last week,
So if I want to be able to arrive late and get the car in the road I need it to be working. So compressor is ready tyres changed 98 in it....
Also the temp is meant to go down to -20 this week. which is a tad early in the year so I drained all the water out above ground level.
Here a snow blower is something you connect to a water hose and a compressor and make artificial snow.
At least the Latvian Foreign Minister took it with ease.
Albert Einstein
One problem is that it's slippery when wet. I suggest mixing in just a little bit of sand to give some traction to the floor. Actually, if you look at those suppliers' web pages, this is probably a known problem and they give you an additive or some other product you can put in the mix.
the politician I suspect he has gone off road in an aircraft before.
Its part and parcel of living and flying in Scandinavia and the Nordics it sometimes happens. The ground is frozen so there is seldom much damage apart from pride. And the fresh snow is a brilliant low G speed arrestor.
Touch wood its never happened to me yet but that more by luck than skill.
Once went out with a ground ops, in north sweden, car to do a Captains check before departure and as he turned onto the runway we started spinning and ended up off the side. And we held for 4 hours until they eventually managed to get the MU above 0.25. Which took loads of chemicals and hot sand. I just said to the tower guy when I was brought in afterwards on a skiidoo. Baking action poo off a shiny shovel....
I have to say though that hot sand you use in the north of Sweden gives a lovely surface on compacted ice.
I really don't know any details. There will be an investigation by the authorities and company but it will take a while for it to be complete.
They will have done a download off the aircraft and sent it over to canada so if it was a machine issue we would have heard about it by now. I was called in off a day off yesterday to sort out the knock on effect of the airport closing afterwards.
On the big roads they just put salt, especially when it is around zero and they don't expect snow.
No one likes it, everyone want's them to stop, it can actually become slippery because of it even, if it is still on the tires when going on a road with just snow and ice.
Never though about it before but is there breaks on the wheels on the aircraft?
Seems like the breaks would be to small for the mass if there where.
Always thought they braked with the ailerons and the flaps.
Albert Einstein
From this week's crop of reports:
The jet that rejected a takeoff at Newark in August (when the tower politely pointed out that they were bombing down a taxiway, rather than the runway they had been cleared to use) had to cool its heels for 45 minutes before being allowed another go.
One at Shannon (also in August) aborted at higher speed than the limitations allow (somebody had left a window open and they thought they had got up to 100 or 120kt, rather the 149 it said on the instruments, against a decision speed of 146) and had been blithely taxying back to the stand for 28 minutes (using braking to help the jet take the corners) when one wheel caught fire.
A.
They are extremely powerful if the tyres can get a grip on the runway.
https://youtu.be/_g6UswiRCF0
We use low energy abort below 80 or high energy above that before v1
A high energy can blow tyres out
To me the gear, tyres and brakes are one the much under appreciated bits of engineering on an aircraft. They get cold soaked at -65 for hours on end and then are expected to give peak performance and a temp rise of 100 plus degs in a matter of seconds.
Sub 80knts the amount of energy they need to absorb is relatively easy to contain at max take-off weight. Over that in some ways it becomes a sacrificial usage of them. An abort just before V1 is a bomb load of energy to deal with, fire may occur, tyre fuse plugs may melt and release deflating the tyres etc.
So there are rejected takeoffs and rejected takeoff's. Which is what we would say on the radio to ATC who just need to know we are not going. But in reality the difference between the two technically and energy wise is colossal.
You can over temp the brakes taxiing in places like Madrid which is hot and high and it can take 30 mins to get to the departure runway and your limited taxing speed. As you can see in the diagram above the modern machines have sensors on them so we get a caution in the cockpit when they get hot. You just have to sit for 10 mins until they get back into the green band. The older machines they have to take the weight and speed ambient temp then go into a table which will give a time which is usually hugely conservative. Carbon brakes V steel brakes is another factor. Short sector multiple cycle short turn round airlines will opt for the steel to aid brake temp reduction. Longer sector airlines long turn round will opt for carbon to save fuel burn due to them being lighter.
Jets are a lot more feisty for directional control when the runway friction is low. For the brakes to give max out put you have to be able to transfer the load through the tyres and if they can't get the friction onto the runway...
Turboprops are easier because you can slam the engines into beta reverse and still get impressive amounts of deceleration. You can also have direction control with asymmetric reverse. And doing that doesn't give you hot brakes.
Braking action poor which is under Mu 0.2 is icerink slippy. you can't walk on it
This is the vid I got shown in training with the message of keep the hell away from the gear.
The brakes are at over 1500 deg C and then they are putting cold water onto them of course they are going to explode sending shrapnel everywhere.
Did you just link a video of a rejected take-off?
I’ll see your silver lining and raise you two black clouds. - Protection Operations
https://youtu.be/HiLeji8bLOk
I don't know what he process is that causes the destructive failure of the brake pack when water is applied in high volumes when they are extremely hot. But know its likely to happen. They are meant to use foam not water to remove the o2 not take the heat out with cold water. I presume its colossal thermal gradients set up internal thermal stresses which causes fast failure. They are split hubs so it could be the hub retaining ring goes and its the tyre pressure which provides a lot of the energy to make things kinetic.
I just know not to let the pax go anywhere near them and not to go and have a look myself.
I have a lot of respect for the gear, tyres and brakes. But I would say I am in the minority. The way we use them day to day can have a colossal effect on maint costs that's even without them doing anything special.
I have never done a performance limited high energy abort apart from in the sim. If I managed to get through my career avoiding that experience I will be happy enough.
And don't know is there is a big difference with these electrically actuated brakes instead of the hydraulic ones which have 2500 + psi of hydraulic accumulator plus engine pump feeding them.
As such I don't really need to know the in's and outs of the failure modes. Just need to know to keep everyone the hell away from them and leave the fire service and techs to deal with them.
What I do know though is Bombardier has arranged that I have full protection as long as 1 of those BDCU's are working and then things get interesting when you in alternative braking mode or using the final apply the hand brake which will cause the tyres to blow out when the wheels lock up. Electrical power has i think 5 backups, to provide power.
But this is pretty much engineering porn
https://www.youtube.com/watch?v=dKlJJqHFfoQ
When I was in the army the filling of the lorry tyres was again taught by a punch to the face if you were anywhere near the things while filling them in the field.
Come to think of it, I wonder how they train soldiers these PC days. Pretty much every safety omission resulted in our QMSI just smacking you one. It was very effective way of installing safety procedures into 18 year old young lads. And they are still with me 32 years later.
A.
Some of the trucks carried a couple of hundred gallons of water.
It was piped to the wheels and nozzles directed the water to the top of the brake drums.
The water was always turned on before starting down the grade so that the heat built up evenly.
On a long hill there would be a cloud of steam from each wheel.
I had a wild ride one day when something plugged the water line to my trailer.
A friend of mine on a long downgrade did not realize that he was seeing smoke not steam from his trailer wheels.
He set fire to and burned off eight tires and was lucky not to lose the logs.
Today, with Jake brakes and disc brakes the water cooled brakes are probably gone.
The latest in Jake brakes is the High Power Density Jake brake.
The original Jake released the hot compressed gas at the top of the exhaust stroke.
The HPD Jake alters the valve timing to admit air on what would normally be the power stroke. (Remember that the exhaust valve has just opened to release the air charge.)
Then that is released at the top of the stroke.
This gives a braking action at each stroke of the piston rather than at each second stroke that the original Jake provided.
Ohm's law
Not just a good idea;
It's the LAW!
They advise an epoxy sealant and 48 hours later another epoxy layer of the same mix with a friction grip additive.
The guys dad lives 20 km away and he wants to replace his dads barn as well so.... He wants a floating foundation like mine and wants the Brother in law to do the forming work. And... 15m by 6 meters will work for him as well... So consultancy fee and keeping the BIL sober to do it is the goods price. And we can dual up for discount off the log barn production guys.
I love this soviet stuff dealing with people. Not dissimilar to oil in Aberdeen where a bottle of whisky could get you a 40 ton artic for a few hours if you needed it or access to a machine shop.
When I grow up we had a neighbor that still is one of my mothers best friends.
He was self employed and hade a tractor firm and he is also is and still are a amateur trotter horse trainer and owner.
He always says "det är bättre med kontakter än kontanter" it is better with contacts then cash.
Albert Einstein
They say that etching will not provide enough profile to good bonding.
That would improve on the quality of seal. Some epoxies have a very small window (<48 hrs) when it comes to a re-application.
The guy just said "yes" when I said that was my intended preparation.
And he was very adamant that the second coat had to be done in a 36-48 hour window. No doing it and leaving it for a couple of weeks then coming back.
As usual my job is small feed.
Its not grit apparently its crushed up shells.
There is a solution that you put on before the first coat but I don't know what it does.
Epoxies in general have primary and secondary bonding characteristics. They bond by adhesion and by polymerization. Once the epoxy has fully polymerized, only the adhesion components of the bond is left. It's important to re-apply coats of epoxy paints before polymerization ends.
So, apply your penetrating epoxy and then subsequent coats quickly afterwards. Don't dilly dally.
Epoxy paints will chalk in sunlight so you may want to consider a cosmetic topcoat, usually polyurethane or siloxane.
He definitely thought it was a good idea to run the grinder over it to get rid of that top crud layer which he said was something to do with O2 exposure during phase 2 and 3 of the concrete curing what ever the hell that is.
It was a great suggestion tug and I am extremely lucky that the guy has bought into my project on a personal level. My gut feel is he knows his poo and it will work so quiet happy to run with it. Plus it gives my brother in law and his mate a weeks work doing his place. And my form work wood gets another use out of it instead of going onto the fire pit.
So all in all its a win win.
And it looks like things are expanding rapidly at work so back to being a Captain, so any luck I can afford to get the barn delivered for my two weeks holiday end of October.
Plastic off no cracking and one set of cat prints.
Bad news is wood has hit 600 euro a ton so it won't be built this year.
Planing on putting on the surface finish then.
Albert Einstein
Unless of course the group wisdom is to do it sooner.
Would have to get the wall surveyed in and cemented though. Which isn't impossible.
Maybe it would be easiest just to have it covered, to keep it clean until you are going to finish it?
Albert Einstein
What are the chances it won't go down much for a couple of years or at all?
During covid there was only two entry points from Russia bring wood in. Now there are none open. And no way to pay for it even if you could get it in.
There is still a Q of lorry's trying to get back to Russia waiting empty at the border. The EU ones trying to get back seem to have got back now.
Better get Red to get her chainsaw out....
And the plastic was getting to be a PAI and I wanted to reuse it before it flogged itself to death. The plastic isn't cheap either these days and it a perfect size to do the sauna when I get round to that and line the steps form work which is the next concreting job when it goes above freezing at night.
Looks nice!
ctopher, CSWP
SolidWorks '19
ctophers home
SolidWorks Legion
I have a friend here in the US with a similar building project.
He is buying small amounts of lumber when he can get a good price.
It may take him all year to get the materials that he needs.
I do like the idea of waiting and then giving the floor a grind before you coat.
It would give you a good surface.
The re-coat rules have to do with the two layers both curing and bonding to each other.
Most epoxy can tolerate having a modest amount of grit added to the topcoat without issues.
So grind then cement wall will work best.
You can always sitt on the patio and drink beer and have some salt and vinegar chips and let them do the running and just make a diagonal measurement to see if it turned out right afterwards, otherwise it's just to start over.
Albert Einstein
Go with metal.
Check on prefabbed steel buildings. Termites will hate you.
Keith Cress
And a steel garage wouldn't have the right look for the place.
Actually I think it needs to be a wood garage and it should be a bit crooked and skewered so it will have the right feel to it.
Albert Einstein
Woodworm and dry rot and wet rot we have bucketful's though
