We have a water treatment plant using the lime and soda ash process. The clarified product has a pH of 10-11 and is used as make-up for our cooling tower. Our Clarified Product water is saturated with calcium carbonate and has caused a lot of scaling in the forwarding pumps and make-up piping. We are investigating the option of injecting 93% sulfuric acid directly into the Clarified Product Tank (CPT) in order to lower the pH to about 9.0-9.5 and minimize scaling downstream. The CPT is made of carbon steel and uncoated. We intend to inject the sulfuric acid through a 3/8" stainless steel tubing into the tank from the top center where there is a blank flange. The estimated acid flow rate is no more than 5 GPD.
Tank dimensions:
The clarified product goes into the CPT by gravity from a height of 16'-6".
Does anybody have any similar experience in doing this, i.e. injecting sulfuric acid directly into a carbon steel water tank?
Without a mixer in the tank, how well is the acid mixed with water? The clarified product does drop from a height of 16'-6" to about a height of about 150" and provides some mixing.
What precautions are needed for this kind of set up, especially with regard to corrosion to tank metal?
Thanks very much in advance!
Sean
Tank dimensions:
Height:21'
Operating height:150"
Sean
