Solidworks Macro to Change the view of drawing
joshF
Industrial
Nov 17, 2021
3
I have a slick macro to open a sw template and make the 3 views for a drawing. However, drawingview1 is a *front view orientation. I would like to add code to switch drawingview1 to a *top orientation. Should be an easy code, I just can't find it. Can someone make a suggestion?
asmPath = swModel.GetPathName
Dim myView As Object
Set myView = Part.DropDrawingViewFromPalette2("Drawing View1", 0.165525838871151, 0.140426998540005, 0)
boolstatus = Part.Create3rdAngleViews(asmPath)
joshF,
I thought SolidWorks did that automatically.
In any case, I would not use it. I usually insert the first view which I regard as primary, then I work out which other views I need. When I start designing, I have no idea what my primary view will be. When I start drafting, I have no idea of what my secondary views will be. Your script cannot anticipate what these will be, either.
JHG
