Contact US
THE DENSITY OF ASTM A387
I'm looking for the density of A387 in ASTM A387/A20 (M) as well but i can not find that information.
From google, i found that density: 7.7-8.03 g/cm3 (0.278-0.290 lb/in3). Could you please teach me where can i find that information in a document or reference?
It would be helpful for me in purchasing.
thank you so much.
Luke Nguyen
vu.nguyen@vifutech.vn
RE: THE DENSITY OF ASTM A387
As A387 can contain anywhere between 0.5%-9.0% chromium - and even individual grades have some wiggle room (e.g., grade 22 can contain between 2-2.5% chromium) - it's not surprising that the references you're finding are providing a range for the density instead of a single value. The vendor you buy from may be able to give you a more concrete value, but you may just have to work with some degree of uncertainty in your design.
I get 7.85 g/cm3. We must have a different GOOGLE here
https://amesweb.info/Materials/Density_of_Steel.as...
Why do you have to be so accurate about the density ?
...oh well, like all of the others, you will not answer any questions once you get what you want ...
MJCronin
Sr. Process Engineer
Ask the supplier for the shipping weight.
I strongly suspect that after all of the agonizing we will find that the shipment isn't actually weighed, but the stated shipping weight is determined by the supplier by applying a standard factor.
They may err on the heavy side.
The cost of shipping a few percent less than the maximum allowable GVW is a pittance compared to the fines and lost time of getting caught shipping a few percent more than the max GVW.
Scale operators may hold an overloaded truck until another truck arrives to take part of the load and bring the weight down to the legal limit.
I know of some extreme cases of trucks having to remove some of their load.
Ohm's law
Not just a good idea;
It's the LAW!
@MacGyverS2000
Hi there! i'm also a student whom work in his covid-19 break. :)
Luke Nguyen,
How accurately do you need to know this stuff? I have memorised the density of steel as 0.286lb/in3, which works out to 7900kg/m3. The standard online reference for materials is MatWeb.com.
JHG
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
