Having problem in modeling stairs in Revit
Usman3301
CA
Hi there, I have recently started learning Revit, and currently, I am stuck on this issue of modeling stairs.
I am working on a Revit model in which I am supposed to provide a structural layout of the building only(Formwork for concrete).
Due to this, I am not considering structural finishes in my model. Problem is that when modeling stairs, my first riser height is greater than other risers and I don't see any option in Revit to edit individual risers. Moreover, I am having issues modeling the landing of stairs as well. I have attached a screenshot of the stairs with notes as well. Any sort of help is appreciated.
Hi Usman3301,
Not to sound like a D*%#, but have you tried Tekla? So much easier to work with and do changes. Also, you won't have to model each item over and over.
