Complicated routing question
IvanNX
SE
I have wire that is routed on top of beams. Distance between beams is 2m but distance form beginning to end of wire varies. I can make model that will add or remove beams from model using expressions to lead arrays, but how to make routing that will automatically add or remove new beams, top points are routing points, from routing points list?
_____________________________
Enjoy your work and have fun!
