Tightness/leak test of shell-and-tube heat exchangers
Hello all,
We have a handful of exchangers that we're pulling during our next TA to blast and clean the tubes. We want to do a tightness/leak test after we've cleaned them and put the bundles back. My question is what pressure should we bring the shell and tube sides up to? I was thinking 1.1x operating or 1.0x design.
Thanks in advance!
Thanks in advance!
RE: Tightness/leak test of shell-and-tube heat exchangers
I'd start there.
What are the operating and design pressures? What is the fluid and what temperature does it run at?
Mote sensitive media such as helium used with a sensitive detector is common as well.
Much discussion on the site, might try a search.
Mike
Will you be using liquid or air to test your heat exchangers ? (you did not state) ..... Makes a big difference
MJCronin
Sr. Process Engineer
