Contact US
Ideas for assembly table motor fixture
Hello everyone. I'm fresh mechanical design engineer so i would really appreciate it if you could help me with some ideas on my problem.
I'm designing an assembly station for mounting the top cover on the motor. I need to create a fixture where the motor will be positioned during screwing, Tho problem is that the motor comes in different sizes (from diameter 350 mm to 580 mm). Bellow is the picture of the motor and i highlighted the mounted parts.
My idea is to use some sort of Festo installation (cylinders) to move the fixtures so they can be modified for different motor sizes, but this option might be to expensive.
Does anybody have any different ideas? I would much appreciate it!
Thank you guys!
RE: Ideas for assembly table motor fixture
Are different sized motors being assembled during one run or are they done in batches of the same size? If they're done in batches of a single size, then there might not even be a need for any sort of automation. The different fixtures could be moved manually and set-up each time before the batch is run.
John R. Baker, P.E. (ret)
EX-'Product Evangelist'
Irvine, CA
Siemens PLM:
UG/NX Museum:
Hand operated toggle clamps accommodating the different motor sizes would be an option.
Click Here to join Eng-Tips and talk with other members! Already a Member? Login
Low-Volume Rapid Injection Molding With 3D Printed Molds
Learn methods and guidelines for using stereolithography (SLA) 3D printed molds in the injection molding process to lower costs and lead time. Discover how this hybrid manufacturing process enables on-demand mold fabrication to quickly produce small batches of thermoplastic parts. Download Now
Design for Additive Manufacturing (DfAM)
Examine how the principles of DfAM upend many of the long-standing rules around manufacturability - allowing engineers and designers to place a part’s function at the center of their design considerations. Download Now
Taking Control of Engineering Documents
This ebook covers tips for creating and managing workflows, security best practices and protection of intellectual property, Cloud vs. on-premise software solutions, CAD file management, compliance, and more. Download Now
Close Box
Join Eng-Tips® Today!
Join Us             Close
