USER FATAL MESSAGE 1250 (OPNPFL)
GuyFawkes
Aerospace
Oct 27, 2021
1
Hi everyone,
First time here. Can anyone lend a hand to me with following problem??
I was making some checks to my model and I've found the same problem in all of the .f06 files. The checks went apparently fine but i got this user fatal error in every single .f06. I paste here an example:
^^^ >>> IFP OPERATIONS COMPLETE <<<
*** USER FATAL MESSAGE 1250 (OPNPFL)
STATUS = 32, FILX = 40, LOGNAME = DBC , NSBUF3 = 1024
FILE = ./xxxxx_2d_m1_xxx_strain_energy_check.xdb
ERROR MESSAGE IS --
El proceso no tiene acceso al archivo porque está siendo utilizado por otro proceso. --> Translation of this: The process does not have access to the file because it is being used by another process.
Thanks!!!
